Joe Ternus
Iowa
Working on my neighbors 2003 bobcat 331 mini excavator. It will turn over with the switch, but wont start. If you run your own wire to the fuel solenoid it will start, but the controls wont work. Verified the switch (atleast how I think it should work), checked all the fuses, and swapped some relays around but still nothing. Is there a safety switch or something in there somewhere where it needs like the seat belt, oil pressure, etc to turn on? We don't have lights, gauges, etc so its like the main switched ignition power isn't turning on or something.
If anyone has the electrical schematics I can work it out from there too.
Joe
uffex
Lincoln UK
Admin
Good day
I have a contact that will forward the wiring diagrams if you still need them.
Kind regards
Uffex
tool_king
new jersey
road mechanic owner
Joe
Do you still the wiring diagrams on this?
Rb 1
Missouri
Joe
I have same problem with mine did you find cause
