Lot of blowby and overheating. No water in oil. I've got 420 lbs compression on 1 and 4 and only 110 lbs on 2 and 3. Suspect head gasket but have been trying for days to get counterweight bolts broke loose to pull engine and do complete job. Should I just pull head and hope that's as far as I have to go?
(Bent a Harbor Freight 3/4 drive ratchet with 3 ft cheater. 1000 lb torque IR impact would not budge bolts. Could not move it with better ratchet and 4th bar. I put penetrating oil on but assume bolts go all the way through counterweight to get to threads.)
All ideas appreciated.
