mekanik
I have a bus in the shop with Wabco Full Pressure Hydraulic brakes. It was towed to the shop
after someone butchered the wiring harness and swapped the brake ECU from another vehicle.
I replaced the fuses and smoke started coming out of the ECU. I ordered a complete
Hydraulic Compact Control Unit for it.
Does anyone here know where to get an adaptor that will fit the reservoir on the master cylinder?
Meritor says not to manually bleed the system that it must be pressure bled.
The Snap-On dealer could not supply us with one.
There are a lot of these on the roads what are mechanics using to bleed them?
Terry
Terry
