brianbulldozer
A few years ago I needed a second machine mounted laser receiver on a job (spreading crushed rock for a big box store pad) so I borrowed my buddy's Apache Bullseye 3+. While we were using it a ribbon cable or ribbon cable connector inside the unit broke. I had it repaired (the dealer sent the unit to the factory for repair which took 2 1/2 months and cost me $375). This past week I used my Apache Bullseye 6 on the dozer cutting a building pad in hard rocky ground. By the end of the first day the unit was shutting itself off at random times. By the end of the second day the liquid crystal display had come loose and was flopping around inside the unit. That night I bought my buddy's Bullseye 3+ from him since he has gone out of business and since the receiver has never been used after I had it repaired. By the next afternoon this unit was shutting itself off at random and I am afraid it might be coming apart. Both receivers have only ever had occasional use and look like new on the outside.
For mounting the receiver, my dozer has a 10" long piece of round bar welded to the top of the blade that I slide a 4' length of steel tube over. Do I need to do something differently with rubber mounts to reduce the shock? Should I not be using the receiver at all in this type of ground? Has anyone else had similar problems? Apache (Trimble) sells magnetic mounts to attach these receivers to excavator sticks. These mounts have no rubber cushions and this seems like a high shock and impact application.
Thanks,
Brian
Thanks,
Brian
