92U 3406
Just wait until you do an EX1200 with cast pads. Probably 1/4 of the bolt heads will just twist off. Then out comes the lance to burn the bolt out.
What sort of stuff have you used it on?1500 ft lbs or torque is what my Milwaukee does so far nothing has not loosened under its "delicate" touch
My mulching head has thirty 24 mm bolts (roughly 15/16 in) that are wet (lubricated) torqued to 590 ft lbs. ( yes, I have a very large torque wrench.)What sort of stuff have you used it on?
I agree, but all you have to do is make one slip with the torch while cutting a nut and just nick a link and your are in it up to your neck.
We've been getting sets of tracks complete, and what I've noticed is that whoever's done the installation of the new grousers has used an oxy-torch to burn the paint, it makes it easier to get the paint off.When you install your new rails be sure you get all the paint off the rails where the pads touch them. Clean the pads good also. They will not stay tight if you don't. Two years ago when our National ACMOC show was at Holt Cat in San Antonio I watch them use a skidsteer with a fork attachment that had a pin sticking out the side of the fork. They stuck the pin into the end track pin boss and drug that track up and down the concrete apron until all the paint was worn off. There was a recall on excavator rails and they were changing a few a day in that track shop.
Yes.Chains and sprockets already installed. Chains have 5/8 holes. Would they be loose?
Soooooo, I took 4 old bolts and the pad seems pretty tight. I thought it would move in the holes. Well, that's what I told the wife. Now how do I break the news she was right.Before I drilled 400 holes I would order the right bolts.
