ktm250rider
So, Im finally breaking down and replacing the chains on my excavator. The pads are in good shape so those are going onto the new chains, so i need to remove ~400 bolts. So far just for giggles i tried a 1/2" impact wrench. Yeah that did nothing. I also tried a 1/2" breaker bar going with the snap the head procedure, yeah that didnt work. I was worried the breaker bar was going to turn into a boomerang. I have an old IR electric 1" impact wrench coming from my brother. Its old! From what i can find, its 750 ftlbs of torque. Not sure if that will be enough to break the pad bolts. I hope it will free up the sprocket bolts at the least.
I think the best option for the pads is to cut off the bolts. However, i dont have any cutting equipment. Ive been putting off too long so i need to buy something. Torch set would certainly do it, but what about a plasma cutter? I have a lot of projects that a plasma would be great, instead of using a cut off wheel.
This is a farm machine and i dont need to get the pads cut off all at once. I was thinking of maybe doing a couple each day over the winter.
