best mulchinh head for ctl
rockman
possibly looking at a mulching head to add to the business
i run a tl12 Takeuchi , 110hp , high-flow machine
been told to look at the fae heads but have just come across the Loftness G3 head
i'm in australia , i know i can get the fae cutter but unsure of anything else
looking for opinions on different brands or even using the disc style mulchers http://www.advancedforest.com/products/ss-series-mulchers-for-skid-steers
thanks
fergy
WA
There are a few to chose from over here
Be sure to get a demo if you can
Have seen too many times someone put an implement onto a machine that can't quite run it
And then not be able to do the job or do it efficiently
Fergy
rockman
Fergy
do you run any mulchers at all ?
KSSS
Idaho
excavation
I think the FAE head is pretty tough to beat, especially with the variable hyd motor. I have a Tushogg which I like in certain applications but it is not as efficient at cutting as it some of the others, but it is great in rocky conditions.
Tones
Ubique
rockman, I don't think Loftness have any proper agents in Australia and compared with other mulchers aren't as productive. Teeth are real expensive at $220 each x 36. AHWI/Fecon are hard to go past and have good engineering design and more rotor configurations.
mwarfel
Lebanon, OH
Rockman Fecon has agents in AU who would be happy to work with you on setting up a demo so that you can take a look at what we have to offer in the way of mulchers. We, as Fecon, have set up many mulchers on the TL12 and customers have been very happy with the performance. CEG/ASVAU is our distributor in AU and you can find them at http://www.asvaus.com/contact-us.html
Thanks
rockman
down to the ordering part ... my machine Takeuchi TL12V2 is approx 1950mm across the tracks
my choices are either the
AHWI 450H1600mm which is in the country
AHWI450H1900mm which is 2-3 months away on a boat
or go the FAE which are in stock at the moment , either the 150vt or the 175vt
people are saying that should go the smaller of the ahwi as the larger one is to much to push around the tree's
any opinions at all from operators ?
Cheers Jim
