dstanek
Hello, I just bought a BD2G powershift dozer. 1989 model. Runs great but transmission is out of it and needs to be replaced or rebuilt. Anybody know where I can get a used transmission or rebuild kit or individual parts for it? I have the trans out and apart. These are the parts I'm looking for if I can get them to rebuild it.
1st speed group
-output shaft
-1st speed planet carrier
-thrust plates (6)
-roller bearing 6909 NACHI
-piston seal
Forward 3rd Speed
-Planet Carrier (1)
-planet gears (3)
-planet thrust plates (6)
-planet gear pins (3)
-roller bearing (3)
-piston seals
5 inner seals 5 outer seals
Complete Gasket assy
Control valve gaskets
Ring Gear
Now you know why I'd like to find a used good trans.... Doubt I can find the indiidual parts I need. But maybe....
Thanks for the help !!
1st speed group
-output shaft
-thrust plates (6)
-piston seal
Forward 3rd Speed
-Planet Carrier (1)
-planet gears (3)
-roller bearing (3)
-piston seals
Ring Gear
