I apologize for never closing this case for you guys.
Bandit obsoleted this particular axle in 2010 according to my best information. Hence they keep no stock or parts (the kind I needed anyway) for this design. They now use 3x 25k axles in place of the 15K on my machine. Apparently, Dexter was building this slightly modified design just for Bandit, so they too were not able to provide any help, with a 4-5 week lead time to custom build replacements. I was able to locate a burnout machine (S.C.) that was being parted out and had 2 axles remaining. I drove across the country to look them over, and to make this a little shorter, ended up buying both. Meanwhile, the shop the machine was towed to was working on getting all the pieces together to rebuild all 3 axles. Fortunately, one was not damaged in all of this, so only the two salvage axles needed a lot of work. Everything seemed to be stop and start due to various factors, and one bit of damage required bringing in an Axle Doctor. We had consulted them earlier on doing their thing to both the original, ruined axles but were told the stubs were not in stock, and would have to be made. The lead time was not that good so we pursued the salvage axles, figuring they would be repairable or usable. As it happened, one of the bearing retainer nuts had pulled a thread and stripped/tore/galled the spindle threads, so we had to do something else. Turns out, the Axle Doctor who also happened to live in the same town as the shop working on the trailer was able to come up with 1(one) correct stub somehow. A few hours one morning and we were back on track. One last "gotcha" was found only when the wheels were being mounted. Several stripped lug studs. Fortunately again, they were not too special and the shop was able to order in and the decision was to replace all of them on one side of the two salvage axles. Once they arrived it was a matter of scattering the hub/brake drum assembly for pressing the studs in. So with all new hardware pretty much everywhere on all three axles, it was done. It took quite a while, longer than normal, but being a specialty machine and not a typical truck or trailer I guess that's to be expected. Somehow, the new owner was gracious and patient enough to allow us to work through several problems and get it done. I'm not quite sure I would have been as patient, but I am grateful.
So in the end, the machine has for all practical purposes, new axles all around, new brakes, bearings, seals, caps, etc., with replaced tires where needed. There were no further mishaps on the delivery run and it works in its new home and everyone is happy to close this chapter on this Bandit. So aptly named.
