Last year I repaired my swing post pins and bushings. I used spring tension bushings because the holes weren't perfectly round. I had a hyd. shop make new 2 1/2" pins. Initially everything was working good. A little while ago I noticed what looked like powdered metal around the top swing pin. Further investigation revealed that the bushing had dropped down about a 1/4". It's a 2" bushing so still had 1 3/4" in the bore. My plan was to pull the pin and pull the bushing back up into place. Then I would add some large spacer washers to prevent the pin from dropping again. I managed to get the pin out and it looked like the bushing may have turned about a 1/4" of an inch. What was more disturbing was the back side of the pin (facing the hoe bucket) was severely worn about 3/16" deep. Front side of pin had some wear/gouging but not too bad. The bushing was gouged and rough but still had a decent thickness.
The bushings are spring steel designed to be the wearing part for cheaper repairs but in this case the pin was severely worn. I'm wondering if the pin material was too soft under the chrome or if once the chrome wore it acted like an abrasive on the pin? I think the pin may have been made from a hyd. cylinder rod. One of the original pins isn't worn too bad so I can reuse it but it's puzzling since the top and bottom pins have to be in line with each other. I'll need to remove the bottom pin as well to replace the bushing and hoping it isn't also severely worn. I don't see any of the powdered metal around it so crossing my fingers.
I could possibly see more wear on the pin near the top of the bushing that slid down but the groove is the full length of the bushing. Has anyone ever seen a pin wear and leave a fine powder behind? I used dry graphite for lube but I think it would have worn off pretty quick.
