Backhoe bucket question, cover teeth
Discussion in 'Tractor/Loader/Backhoes' started by James Riley, Jun 19, 2015.
  1. James Riley
    James Riley New Member
    Jun 19, 2015
    3
    Colorado
    Hi folks. I'm not much of an operator. I have a Ford 555 with an 18" and a 24" bucket. Have you ever heard of an add-on that covers the teeth, making for a smooth or flat scraper? Without having to take the teeth off (i.e. it just bolts or otherwise just goes on over the teeth)? If so, how about one that sticks out a foot or so on each side? Where I might I buy one? Thanks in advance of any help.
  2. CM1995
    CM1995 Super Moderator
    10,555
    Welcome to the Forums James Riley!:drinkup
    Usually if one needs a flat scraper blade on a backhoe bucket just weld a piece of cutting edge or flat plate to the teeth. It's easy to burn off after your done using it if there is enough meat left on the tooth or just change the teeth out if not.
  3. willie59
    willie59 Super Moderator
    Dec 21, 2008
    12,724
    Service Manager
    Knoxville TN
    That's what I typically do. If it's just a short job and you'll be taking it back off soon, just use hot rolled flat steel. If it's going to stay on the bucket for a long time you might want to use an AR plate or a cutting edge blade like CM suggested.
  4. farmerlund
    farmerlund Senior Member
    Nov 23, 2014
    815
    Farmer/ excavator
    North Dakota
    I made a V shaped cutting edge that fits over the teeth, front is 1 inch thick cutting edge, back is 1/2 plate. It has a chain welded to the back that I run up to loop on back of bucket and tighten with a load binder. once it is wedged on tight it stays tight.
    Mine is on a 48" bucket on 210 Volvo excavator.
    Blademandan likes this.
  5. hookedondiesel
    hookedondiesel Senior Member
    Jan 24, 2013
    455
    Eastern Ontario 1994 JCB 210S 4X4X4
    How about a half inch thick plate, the width of your bucket...
    then weld on some muffler clamps, bolt them on your teeth when needed.
  6. jimg984
    jimg984 Senior Member
    Dec 2, 2009
    584
    ronda north carolina
    then the 1st time you push backward go pick it up.and weld it on
  7. CM1995
    10,555
    Not if you have a good welder.:cool2
  8. jimg984
    Dec 2, 2009
    584
    cool2, I was talking about the bolt part of the muffler clamp, I have tried bolt on things thinking well just wont push back, and I didn't push back for about 30 seconds lol that's an old man like I'm lol
  9. hookedondiesel
    Jan 24, 2013
    455
    I don't think 1/2 inch U bolts and their nuts would break, I'll be making a set soon and let you know how they turn out.;)
  10. CM1995
    10,555
    Gotcha!
  11. dixon700
    dixon700 Well-Known Member
    May 11, 2014
    210
    heavy truck mechanic
    pa
    I was thinking of building something bolt on. Use some 1/2" or thicker material and build a v then run a couple straps back and drill a couple holes in the sides of the bucket. Welding a pies of Chaim toneach side and binding it around sounds like a pretty good idea.
  12. Orchard Ex
    Orchard Ex Super Moderator
    Jul 7, 2005
    1,051
    Southern MD
  13. James Riley
    Jun 19, 2015
    3
    Colorado
    Your responses were exactly what I was looking for. I want to thank you all for taking the time to respond. You saved me from having to buy another machine I couldn't afford.
