Auger Stump Planer/Grinder/Shaver
Discussion in 'Equipment For Sale/Wanted' started by ibhurln, Feb 1, 2018.
  1. ibhurln
    ibhurln Member
    Sep 6, 2016
    12
    mechanical design
    florida
    Up for sale is a combination Auger & Stump Planer bit for a skid steer. We bought it new in october to clean up stumps around the farm, and it still looks and works like brand new!
    It works awesome, literally shaves the stumps down...peels off layers of wood that look like thin sheets of plywood...way faster than a traditional stump grinder, too.
    The stump planer is a 14" diameter model from Eterra.
    The Auger is a CID Xtreme Auger with planetary reduction puttting out 3,500 ft. lbs. on standard flow-will turn a 48" diameter auger bit with ease.
    Below are descriptions from manufacturer's:
    The Stump Planer uses 3 steel tool cutters and a starter tip, which can all be sharpened or replaced throughout its life. You simply position it over your stump and start grinding it away. It will go up to 18 inches deep, so rest assured the entire stump can be erased from the surface. It features guides on the trailing edge of the cutters, so there is now way the planer can jump back out of the hole. The starter tip feeds the planer all the way through the stump, so it doesn't overload itself with cutting surface and prevents it from getting stuck. Just consider how much you would pay for a dedicated stump grinder? They cost several thousands of dollars. The money you are spending paying others to remove the stumps is also adding up real fast. This Eterra Auger Stump Grinder will essentially pay for itself after two stumps.
    A really neat advantage to this style of planer is that you can drill all of the way through the stump which is much deeper than a regular grinder is capable of. Most dedicated stump grinders can go 6 - 10" deep into the ground. This attachment can be used in conjunction with auger extensions and drill for many feet.
    CID X-treme Skid Steer Auger Attachment Specs
    Our CID X-treme Skid Steer Auger Attachment has an continuous pressure rating of 3,000 psi and a intermittent pressure of 4,000 psi. The auger consists of a motor mounted directly to the planetary gear box with no chains to break or come loose. It comes complete with mounting plate, hoses and couplings. There is no need to pay extra for anything. The output shaft is a 2” hex drive and is powerful enough for the toughest jobs.
    • Direct drive through planetary gear.
    • Mounting plate, hoses and couplings included.
    • Various auger bit sizes and styles are available.
    • Heavy duty output shaft.
    • Capable of driving up to 48″ bit. stump planer 6.JPG stump planer 5.JPG stump planer 2.JPG auger 2.JPG
  2. pondo
    pondo Well-Known Member
    Mar 24, 2013
    157
    canada
    So how much $?
  3. ibhurln
    ibhurln Member
    Sep 6, 2016
    12
    mechanical design
    florida
    oops, forgot to put that n the post. $3,500
