Thank you for visiting HeavyEquipmentForums.com! Our objective is to provide industry professionals a place to gather to exchange questions, answers and ideas. We welcome you to register using the "Register" icon at the top of the page.
We'd appreciate any help you can offer in spreading the word of our new site. The more members that join, the bigger resource for all to enjoy.
Thank you!
Try tapping th tie end on the top to force the taper back downinto te steering knuckle as you try to tight it or loosen it it you want to remove it from knuckle.Sometimes this work with ease.Sometimes you need to spit the nut to remove it from knuckle also.
You might be able to grab the shaft above the knuckle w/ vice-grips. If you don't have room for regular ones, try needle nose, just make sure you use the base of the jaws.
Thanks fellas! I tested the passenger side and it was nothing like the driver side (VERY loose). I figured I would be replacing it.
Thanks again for your tips!
