Anyone know what this is?
Discussion in 'Excavators' started by Kimo, Oct 17, 2020.
  1. Kimo
    Kimo Member
    Sep 15, 2017
    22
    BS
    Trying to run down a crank no start on Cat M312 (3054). This looks like it should just be a ground but the red wire is bugging me. Not hot when key on.
  2. funwithfuel
    funwithfuel Senior Member
    Mar 7, 2017
    3,267
    Mechanic
    Will county Illinois
    Looks like a flame start.
  3. Nige
    Nige Senior Member
    15,642
    Ground wires on Cat are almost exclusively black. If you don’t have an electrical Schematic post a Serial Number.
    LACHAU and DMiller like this.
  4. John C.
    John C. Senior Member
    Jun 12, 2007
    8,159
    Used to call those a fire breathing dragon. The early generation Komatsu D155 dozers used them. I had never heard of them being used on a Cat, but that engine looks more like a Perkins than a Cat.
  5. Nige
    Nige Senior Member
    15,642
    Glow plug. The red wire is fed from a relay through a resistor to the glow plug.
    The orange wire to pull in the relay gets its power from the key switch.
    mg2361 and LACHAU like this.
  6. LACHAU
    LACHAU Senior Member
    Aug 11, 2009
    321
    Hochiminh City, Vietnam
    Perkins is a subsidiary of Caterpillar. some Perkins engines and Caterpillar engines are interchangeable, they are exactly the same.
    Caterpillar 3054 is similar to Perkins 1004-40
    1E20E75F-37D8-4673-8970-65FB4B0519BA.jpeg 19128FBD-F5B0-454D-B87A-606DBBE511A2.jpeg
    DMiller, Vetech63, mg2361 and 2 others like this.
  7. Kimo
    Kimo Member
    Sep 15, 2017
    22
    BS
    Thanks fellas. I can dump that. One less thing to fail.
    DMiller likes this.
  8. funwithfuel
    Mar 7, 2017
    3,267
    Mechanic
    Make sure you have a perfect plug on the fuel line or it will cause you grief.
    mg2361 likes this.
  9. Kimo
    Kimo Member
    Sep 15, 2017
    22
    BS
    This is like a old made up comedy bit...except for the comedy part.
    Here's the chain of events...
    I had a small leak coming from turntable, no other leaks or issues. Since hydraulic fluid cost $50 a gallon here, I thought it prudent to stop the leak. So I pulled and resealed swing motor. No more leak! I used the machine for about an hour and the right stabilizer seal blew out. I blocked the line and went back to work. 30 minutes later the stick cylinder blew. I repacked the stick cylinder and went back to work, within 20 minutes both blade cylinders blew. None of these are seeping oil, they are just exploding. I've dumped 50 gallons of new CAT TO-4 fluid on the ground. I chained up the blade so I could go back to work and the force from the blade snapped the chain, twice. I switched to a heavy 3/8" grade 80 chain. I was able to get limited use for a few hours with the blade and stabilizer chained up. Then the batteries mysteriously started draining empty over night. Charged and tested batteries, they're fine. Could find no obvious draw. This went on for a few days, so I started kicking off the battery cutoff anytime I turned the machine off. This kept the batteries from dying. Then 2 tires blew (same hub). I replaced the tires, fired up the machine, moved 3 feet and the left stabilizer cylinder started leaking. I shut it down. Went to start it the next day and it just cranks, no start. Checking, I found the main fuse was blown (60amp). Replaced the fuse, turned on battery and burned the fuse again.
    This all happened inside of 3 weeks. I doubt I put more than 3 or 4 pampered hours on it, total.
    WTF is happening here? It's like it's infested with tiny snickering gremlins.
    Anyone ever heard of anything like this? Something blowing a 60a fuse should be obvious, but I can find no culprit.
  10. funwithfuel
    Mar 7, 2017
    3,267
    Mechanic
    Alternator rectifier crapped out maybe? Will act like a dead short overnight. Dont know if that would have killed your ignition feed fuse.
    mg2361 and DMiller like this.
  11. John C.
    Jun 12, 2007
    8,159
    The joys of running old worn out machines.
  12. skata
    skata Senior Member
    May 10, 2007
    875
    midwest
    Wow. Was this machine sitting for a long time? Plastic and rubber deteriorate with age, and then when put to work, they fail.?
    John C. likes this.
  13. Kimo
    Kimo Member
    Sep 15, 2017
    22
    BS
    Starter and alternator are on another fuse. They're operational.
  14. Flat Thunder Channel
    Flat Thunder Channel Well-Known Member
    Apr 24, 2020
    169
    Ohio
    Mouse special? I hate mysterious wiring faults. That is a a huge fuse. Look around for the hot spot in the wiring. It has to be heating up pretty good to blow a fuse that size.
  15. excavator
    excavator Senior Member
    Oct 16, 2006
    1,008
    Pacific North West
    And if I'm not mistaken they are all built by Shibaura.
