Anyone know, what this is ?
Discussion in 'General Industry Questions' started by cw4Bray, Nov 8, 2018.
  1. cw4Bray
    cw4Bray Active Member
    Sep 27, 2017
    42
    SD
    How does it work ?
    Thanks !
  2. Theweldor
    Theweldor Senior Member
    Feb 17, 2018
    295
    Western, NY
    That appears to be the frame of a rock truck. Keep your eyes open and the cab, tires, axles and box (sometimes in 2 pieces) will be following along shortly.
    Mother Deuce likes this.
  3. kshansen
    kshansen Senior Member
    Mar 11, 2012
    6,560
    Central New York, USA
    Yep like Theweldor says, you need a few more parts!
    That round drum like area with the Komasu on the cover is most likely where the drive motors for rear wheels bolt in and the pads with three bolt holes on the upper two and the four bolt holes for the bottom two would be where the front suspension cylinders mount. One of the steering cylinders is hanging from the bolt hole to the left on the lower pad.
    Hope you don't need this truck for Monday morning or some one is going to be working long hours this weekend! Junkyard might be free if you need help!
  4. petepilot
    petepilot Senior Member
    Jul 7, 2018
    522
    central shenandoah valley va,
    screwdriver pair of pliers and a bfh whip that thing together in about 40 min. AFTER YA GET THE REST OF THA PIECES
  5. AzIron
    AzIron Senior Member
    Jun 15, 2016
    420
    Az
    How fast do they go together I have never been around when they go together or come apart
  6. Theweldor
    Feb 17, 2018
    295
    Western, NY
    From the ones I have been on it is pretty easy to have a couple of weeks. Depends on the size and how much welding needs done.
  7. funwithfuel
    funwithfuel Senior Member
    Mar 7, 2017
    1,650
    Mechanic
    Will county Illinois
    That ain't no hunnert tonner, not with 24 cylinders. Unless it needs 12 extra to compensate for the emissions.
  8. funwithfuel
    Mar 7, 2017
    1,650
    Mechanic
    YouTube komatsu 980e Komatsus largest hauler. Electric drive.
  9. hosspuller
    hosspuller Senior Member
    Aug 28, 2014
    779
    North Carolina
    I wanna see someone do an inframe on that engine. The rear section seems a bit tight to the frame all around.
  10. petepilot
    Jul 7, 2018
    522
    the pile of turbos on there is impressive
  11. John C.
    John C. Senior Member
    Jun 12, 2007
    5,889
    The mechanicals go together pretty quick. Large crane and four people and two big service trucks. The biggest issue I saw with them was the boxes come in two halves that have to be welded together. The number of days it takes depends on the amount of over time is allowed. Most crews work half days. One crew works 12 hours and then the next crew comes in and works the other twelve hours.
  12. catman13
    catman13 Well-Known Member
    Aug 22, 2011
    246
    oregon usa
    some assembly required :)
  13. Ronsii
    Ronsii Senior Member
    Jun 26, 2011
    1,200
    s/e Heavy equipment operator
    Western Washington
    Just like Ikea :D
  14. Nige
    Nige Senior Member
    10,777
    I was going to say that.........
    I don't know about Komatsu boxes John, but the 789 and 793 boxes I've worked with came in 4 pieces, centre section, LH & RH side sections, & headboard. The wear plate packs came separately. The welders worked 2 x 12 hours shifts to nail them together.
    https://www.heavyequipmentforums.com/threads/new-toys.29487/
    Mother Deuce and alco like this.
  15. Nige
    Nige Senior Member
    10,777
    No in-frames, no mid-life injectors & turbos, even the overheads only get run every 4000 hours. End of life, snatch the whole engine/radiator/generator power pack in a single lump. On earlier Komatsus the complete power pack rolled out of the front of the frame on rails, never been around a 980 so couldn't comment.
  16. cw4Bray
    Sep 27, 2017
    42
    SD
  17. cw4Bray
    Sep 27, 2017
    42
    SD
    I'm impressed by the trailer !!
  18. cw4Bray
    Sep 27, 2017
    42
    SD
    A big THANKS !!! to the Theweldor for knowledge and answer.
    Also impressive was the size of the radiator, it looked like something you'd see on a 3000 HP stationary generator.
    PetePilot's also correct, that's ...much... much... more than scavenge air on a two cycle engine. I wonder how much boost is being produced ? Are we talking about three atmospheres or 120" of MP or just 60 psi ?
  19. Crummy
    Crummy Senior Member
    Jul 9, 2017
    450
    PacNW
    One of the old gang recently
    860E
    129,000#/210,260# gross
  20. cw4Bray
    Sep 27, 2017
    42
    SD
    Brief specs of the 980E-4 are: Payload, 363 tonnes (400 US tons); body capacity by design; engine, KomatsuSSDA18V170 QSK78 rated at 2611 kW; maximum loaded speed, 64km/h; braking system, 4476 kW electric dynamic retarder plus wet disc brakes front and rear; tyre size, 59/80R63(standard)
