Peter_H
I have a 410 JD backhoe that came with the Wain Roy twister quick change bucket coupling on it. It came with an 18 inch and a 24 inch bucket. I need to do a trenching job on my property where a 12 inch bucket would be far better. I found a wicked good deal on a Wain Roy badged 12 inch bucket, but it has the smaller 1-1/2 inch pin hole on the bucket. Mine has the larger 1-3/4 inch pin hole. I could open up the hole to my size pretty easily, but I'm not sure if the distance between where the square opening for the boom mounts and the pin hole will be the same. Has anyone ever done this? I've tried to find some specs showing measurements on the different style buckets, but so far have not been able to find any. I know allot of guys don't like these buckets because they get sloppy when worn. But I tightened both of mine up fairly easily by welding flat shims on the bucket. And the machine is not out making money, so they stay tight for me. The price is right on the bucket I found, but I hate to buy it, bore out the pin hole, and then have it not fit. Any input would be helpful.
