Funny farm
- Joined
- Apr 21, 2018
- Messages
- 206
- Location
- Ontario Canada
- Occupation
- Red seal,high pressure certified welder
All four cyl bores had the same repair too. Don’t know if I said that. After removing the other sleeves u can see three repair rings still in place in the block and the one that came loose. To the best of my measuring ability it appears to be .002-.003 thou bigger than the bored out area. So a normal press fit. ( I don’t have bore mics only a digital caliper)
It’s also bigger than the sleeve is and bigger than the hole top or bottom of the bore so the ring must be distorted just to get inside the block. Obviously it worked and sealed up for years without issue. And could likely be repaired again and would work for years again. But my gut says to look closer at the other block and see if it’s in better shape. May or may not be. The way this project is going so far ,...nothing would be a surprise hahahahaha.
