Another premature failure
Discussion in 'Rollers' started by Vetech63, May 21, 2018.
  1. partsandservice
    partsandservice Senior Member
    Feb 14, 2011
    543
    Georgia
    Charge pump flow typically goes as follows : suction to charge pump, charge pump to filter. filter to loop. So the metal in the filter came from the tank. IMO course of action would to repair or replace motor, disassemble inspect and repair drive and charge pump as necessary, replace case drain lines, inspect and clean all related case drain fittings, clean tank and tank filter housing or filter head. Replace propel hoses. Not getting it all can result in repeat failure and in a hurry to boot.
  2. Vetech63
    Vetech63 Senior Member
    Aug 10, 2016
    1,103
    Oklahoma
    Getting all the contamination out of this hydraulic system will be impossible without replacement of the entire system (or disassembly and cleaning). Its unlikely with this customer to go to that kind of expense much less the downtime. This is the main reason I try to stay away from these failures. I'll do what the customer wants to do, but with NO WARRANTY. I'm betting, besides rebuilding the motor and cleaning a few hoses, nothing else will happen. It more than likely will fail again but its their money. I will recommend (providing Im right about the repair) getting rid of the machine.
  3. partsandservice
    Feb 14, 2011
    543
    Georgia
    After hearing all that , the course of action IMO would be run don't walk away.
  4. John C.
    John C. Senior Member
    Jun 12, 2007
    5,601
    At this point the machine is little more than scrap metal. The due diligence you might accomplish for your customer is spend a little time on the computer looking for a replacement and potential replacement costs. Lay out maybe a couple of lesser repairs with less tear down and cleaning accomplished with the same proviso you have just given. "No Warranties Express or Implied." You might in one instance find a used motor, change oil and filters and just give it a go for X dollars and the lesser expense range or do a new motor with a complete tear down and clean out at the top repair range. What are the chances of the machine failing again soon after each type of repair? Your customer can then weigh that against the potential cost of finding another unit. Lay all that on the table and you will impress them to no end and likely have them making your house payments for the foreseeable future.
    mg2361, Vetech63 and funwithfuel like this.
  5. Vetech63
    Aug 10, 2016
    1,103
    Oklahoma
    Pretty much in line with my plan here.
  6. Vetech63
    Aug 10, 2016
    1,103
    Oklahoma
    After what was supposed to be 1 week getting the parts for this, I finally got them today. Will update as I progress!
  7. Vetech63
    Aug 10, 2016
    1,103
    Oklahoma
    Motor is going in today, system flush as best I can tomorrow. We'll see how it turns out. Hopefully back to work with no issues.
  8. Vetech63
    Aug 10, 2016
    1,103
    Oklahoma
    BomagBW211D40.jpg Well, she's back together! Everything looks good, steady charge pressure, no leaks. Only time will tell...……….and got it all done for 2/3's the cost of a replacement motor alone. Customer is a happy camper at the moment.
  9. funwithfuel
    funwithfuel Senior Member
    Mar 7, 2017
    1,452
    Mechanic
    Will county Illinois
    Any info about this source you have? You said you got OEM parts for much less than originally quoted by dealer. Inquiring minds (cheap bast@rds) want to know.
  10. Vetech63
    Aug 10, 2016
    1,103
    Oklahoma
    www.flinthyd.com 901-794-4884 Duane Bingel. They have fixed me up several times with replacement OEM drive motors for 1/3 less than the manufacturers cost. The parts I needed for this bomag motor were priced at the dealer for a bit over 13K......that's just the parts, the entire motor complete was 12K......if they could get it. These guys fixed me up with the exact same OEM parts for 5K. If anyone needs any drive motors or parts....well worth contacting these guys first!
    DMiller, Tones, mg2361 and 1 other person like this.
  11. funwithfuel
    Mar 7, 2017
    1,452
    Mechanic
    Awesome, and thanks. Always looking for a vendor who's not gouging and offers a good product. Thanks for sharing.
  12. mg2361
    mg2361 Senior Member
    Jul 5, 2016
    431
    Equipment Technician
    Pennsylvania
    Good job Vetech! I feel your pain. I am going through same thing with a JD mini exc that granaded a hyd pump. That info about Flint Hyd's will come in handy. Thanks for that info.
  13. Vetech63
    Aug 10, 2016
    1,103
    Oklahoma
    Still going strong! :D
    mikebramel likes this.
  14. Junkyard
    Junkyard Senior Member
    Jun 5, 2016
    2,764
    Field Mechanic
    Claremore, OK
    I rest easier everyday it runs whether anybody knows I had a hand in it or not!!
    Vetech63 likes this.
  15. Vetech63
    Aug 10, 2016
    1,103
    Oklahoma
    I'll try to save you one that will keep you up at night. LOL
    kshansen likes this.
  16. Junkyard
    Jun 5, 2016
    2,764
    Field Mechanic
    Claremore, OK
    Gee thanks! Haha. I’ve dug into a few things on the rigs that had me on pins and needles for a bit!
