This project got delayed by the customer right after I posted this...……...until now. Progress reports coming soon.
First thing out of their mouth," can't you just?" I cringe whenever I hear that.
I cant prove the main pump is bad due to the fact that it holds steady charge pressure at 400 PSI. The case drain hose on this motor had several pieces stuck in the elbow that wouldnt pass through the hose ID so theres that. The reaf diff pump has no signs of contaminants that I have found as of yet. the front drum pump has definitely had small, fine material run through the pump, that I feel certain about.And the filter only catches a fraction, right. That's Hydrostatic? So the rest of the grenade returned to the pump to wreak more havoc?
New motor is 12K.That thing is "toast".. {in my opinion}
