It's possible that someone else may have posted this problem. If so, please forgive me and direct me there and I'll read. If not, here goes:
2003 NH LB75B, 5200 hours.
Problem: Starter turns engine over only a 1/4 of a turn and then goes click click, as if the batteries are dead.
Additional info: Dual batteries, both fully charged, at least 600 CCA each.
Cables: Removed and tested. All checked out fine.
Starter: Original was removed and rebuilt 18 months prior. New starter was installed.
Testing: 12 gauge wire was run from positive of second battery in line to positive post on starter. Starting attempt produced no temperature change of smaller wire. Wire was then run from the ground post to the starter ground with the same results.
Ground lockout was bypassed.
Additional ground strap was added to starter mounting bolt to ground block connected to cable from ground lockout.
All mounting posts/bolts and cable ends were wire brushed.
Heavy duty battery charger connected to batteries and set to 'boost'.
Heavy duty jumper cables run from my running, dual battery, diesel truck and attached to actual starter post and ground cable attached to the grounding strap, and to the alternator bolt.
Relays next to ignition switch were removed, cleaned and reinstalled.
One relay was found in engine compartment on firewall. It was removed, cleaned and reinstalled.
Wire to intake preheat was removed, no change, so reconnected.
Air temp is low to mid 30's F.
Engine oil has approx 40 hours on it.
So, engine turns over like it's a dead battery(s) or bad cables. All have been tested. Bad starter?, replaced. Jumped from running truck. Ground cable added. NO CHANGE!
Each of the items above were done separately, starting was attempted, and then each was returned to original setup.
Any ideas, or am I at the unhappy point of paying $120/hour for local shop to come out and do the exact same stuff I did to locate the problem?
