dwkern
I have a Groves AMZ 66XT Manlift that functions fine with the exception of the drive speed. It moves at about 1/5 of the speed that it should, in both forward and reverse. The machine Is hydraulic drive, with a drive motor for each wheel. I’ve jacked the unit off the ground and each wheel turns at about the same speed in both forward and reverse. It has a low and high speed setting. The wheels only move in high speed. While it seems strange, increasing the engine speed, actually slows down the wheel rotation speed. I have checked the main relief valve and the hydraulic pump puts out the correct pressure and the relief valve relieves at the correct pressure. I have checked the electrical solenoid valves that control the oil flow to the drive motors and they are functioning properly. Any suggestions would be welcome.
