Almost rotted or rotted steel hydraulic lines
Discussion in 'Dozers' started by lilb93, Jan 20, 2015.
  1. lilb93
    lilb93 Well-Known Member
    Dec 8, 2014
    52
    coal country in PA
    I am sure a few of you have came across a rotted steel line on equipment. There is no need to go to Cat or John Deere or anyone for that matter of fact. You can make the yourself real easy. DSCN0822.jpg DSCN0823.jpg DSCN0825.jpg
    On the bottom photo which is 3/8 steel line. You need a good tubing bending tools. Expensive NO. The best one I have found was from Harbor freight for 6.00 and yes I have hydraulic one's but the 6.00 one beats them hand down for ease of use. You will need a flaring tool for 37 degrees. 45 degrees will NOT work. You only flair then SINGLE seat NOT double seat.
    You will need new nuts and Nut adapters. The nut Spacer or adapter is your second seat.
    The nuts you can get from PARKER. For 3/8 line the number is 6 BTX-S. The seats for 3/8 line are 6 TX-S
    All you have to do is change the front number if using other size lines.
    4= 1/4", 6=3/8", 8=1/2", 10=5/8", 12=3/4", 14=7/8" 16=1"
  2. g_man
    g_man Senior Member
    Apr 21, 2011
    309
    Retired
    Northeastern VT
    You are right. They are not hard to make if you have a bender. You can also use flareless fittings so you don't need a heavy duty 37* flaring tool.
    I remade these lines with Convert-A-Flare fittings.
    I put an extra fitting on the female end so I could torque the flareless joint on the bench and not try to do it in the tight equipment space. Here is the male and female ends. They take up more room the way I did it.
  3. lilb93
    Dec 8, 2014
    52
    coal country in PA
    We use them here to repair a line thats broken in the field. I never had luck with then in the long haul. They either leaked by the crimp or came off all togther. The flaring tool from 5/16 to 5/8 is about 40 bucks.
  4. zbo2
    zbo2 Well-Known Member
    Oct 27, 2009
    143
    southern new jersey
    Where can you get the seemless steel tubing?
    Thanks
    Joe
  5. RBMcCloskey
    RBMcCloskey Senior Member
    May 4, 2011
    387
    Heavy Construction Contractor
    New Jersey
    Thanks great ideas!
  6. kshansen
    kshansen Senior Member
    Mar 11, 2012
    10,392
    Central New York, USA
    I'll butt in a little here. I am able to purchase the seamless tubing from the same dealer that sells hydraulic hose and fittings. They will also make the lines up for you if you wish. I have had good luck with the flareless fittings. might depend on the application. Last place I used them was the steel line from one side of the boom on a Case 1845 C to the other for the tilt cylinder lines. 1/2 od tubing
  7. zbo2
    Oct 27, 2009
    143
    southern new jersey
    The 2 local Hydraulic hose shops near me don't carry the tubing... one is a Parker store. Also there is a third that I deal with online, same thing though... they don't have anything for steel lines.
  8. maddog
    maddog Senior Member
    Apr 20, 2009
    730
    middle TN
    nice work, always good to see a way to make something that cost less.
  9. g_man
    g_man Senior Member
    Apr 21, 2011
    309
    Retired
    Northeastern VT
  10. brianbulldozer
    brianbulldozer Well-Known Member
    Dec 25, 2010
    186
    W. Washinton, USA
    For those small lines that run down by the belly pan and seem always to get buried in dirt and eventually rot away, I go to my local hydraulic shop and have them fabricate a replacement out of stainless steel. I have made my own lines before out of steel hydraulic tubing, but have not tried the stainless myself so don't know how much more difficult it is (if at all) to fabricate.
  11. zbo2
    Oct 27, 2009
    143
    southern new jersey
    Thanks, always forget about McMasterCarr................
