Recently bought an allis chalmers 7g. Anybody have any knowledge or spare parts. Ive got a parts manual and a tech manual for the final drive need a manual for the hydraulic system. Thanks
Hi Kevin, I'm new to forum. I have acquired a 7G as well and need a source of other owners knowledge. This is my post I just added, if you know of anyone. Thanks, Mike Lambert (bluegras)
I have acquired an early model 7G, serial # 22671. It was parked for not steering. As I am going over the machine, I have replaced hyd hoses that were leaking, changed out all of the oils, cleaned all of the screens that I have found and changed all the filters.
Engine starts easy and sounds good. I found a spring that was stretched on the fuel injector that was not letting the engine rev enough, replaced the spring so I hope that will build more pressure to the torque converter. Haven’t tried that yet.
I am pretty sure the right brake band is broken as the adjusting nut is not connected to anything.
My next step is to check the steering and torque converter pressures. Which finally brings me to a question. I have replaced the gauges for fuel and both hyd gauges. I may have installed to heavy of gauges, fuel pressure reads about 10 lb’s, torque gauge that is plumed into oil line that goes to oil cooler reads 25 lb’s, and the gauge that says operating pressure is at 0.
Does anyone happen to know what these should normally read?
I guess my next step is to remove the seat and try to find a place to read the steering pressure?
Sorry for the long letter but thanks for anyones help
