I suspect that my marklift 62 foot boom hydraulic pump may be sucking air when it starts making a loud noise when I engage any of the boom functions such as lift or extension or rotation. This happens on every function and the function will operate normal for anywhere between 2 to 5 Seconds before the hydraulic pump starts making a loud noise and the function stops until I activate the function again a few seconds later. So for example, the Boom Lift will only rise about a foot or two at a time before it's stops and the main pump makes a loud whining noise, as if it is out of fluid and pumping air. I see no sign of a leak or dripping between the hydraulic fluid storage tank and the pump suction line. The main hydraulic filter is on the return lines just before the storage tank. I'm wondering if perhaps there could be debris in the bottom of the tank where the suction line goes to the hydraulic pump? Or if there is some kind of an air bleed knob for the main pump? The pump sounds normal when I engage the foot pedal in the basket before engaging one of the feature valves. so therefore it seems okay with the Pilot low pressure around 200 lb. It's just when I engage one of the features and the high pressure kicks in that the pump stops after several seconds. Should the hydraulic pump clear out any air in the lines on its own if I let the machine run for a minute or two before engaging any features?
