lighthousealarm
Just a quick question. I removed the air cleaner housing shortly after buying a 70's model Case 580CK with the diesel engine. What I found was a mess. What appeared to be the element was nothing but a sludge mess. It apparently is a wet bath type element, and had been neglected for a long time. It is so bad I have elected to replace it. My question is this. Is there any reason why I can not just replace the housing with an after market automotive air cleaner housing and dry element? I have found several available in the $25 range that have the correct base size to fit the intake hose. I am currently running it with only the pre-air cap installed, but obviously do not want to do that very long. Thanks
