Zachary Cullen
Morning guys. I'm having a strange issue with my c 7500 Chevy single axle dump. When I set the brakes, everything works as it should, I can release the brakes and it works fine, the next time I set them, not enough air comes off and it takes the spring brakes about 30 seconds to come on. While this is happening, air is slowly leaking from the parking brake quick release valve, I pinch off the line to the maxis and air stops.
If I try to release the spring brakes from the cab, they release but the knob will not stay in but the brakes are release and I can roll the truck. If I step on the brake I am getting air out the service side glad hand.
What I have done-
1- changed the in dash valve, it was leaking a little anyways so no big deal and it helps eliminate one part.
2- I took apart the parking brake quick release valve and found no obvious issue, inspected it and put it back together and reinstalled.
The same issue persists. Where do I look next? Tractor protection valve? I'm kind of at a loss, had a pretty good mechanic look at it the other night and he was stumped as well. I was going to try to bypass the tractor protection valve tonight and see if that would fix the issue, then I can replace it....just hate to throw parts at it and spend a ton of money on what I don't need.
What I have done-
