Aftermarket hydraulic side shift
Discussion in 'Tractor/Loader/Backhoes' started by Skipo, Feb 23, 2021.
  1. Skipo
    Skipo Member
    Feb 23, 2021
    6
    Hi, I'm new to the forum. I have a 2008 new Holland 110lb. It has manual side shift, but I want to add a hydraulic side shift. Can you get aftermarket kits for this.
    Cheers in advance.
    Skipo
  2. aighead
    aighead Senior Member
    Apr 25, 2019
    619
    Dayton, OH
    Whoa! Manual as in you use the hoe to slide it?
    Also, is it safe to assume you have a biga$$ saw blade on the end of that thing? Sweet!
  3. Tinkerer
    Tinkerer Senior Member
    May 21, 2009
    5,844
    On A Riverbank in IL. USA
    Welcome to HEF, Skipo !
  4. Skipo
    Skipo Member
    Feb 23, 2021
    6
    Yes. You push it from side to side using the hoe. However I can't do it when I have the saw attached to it.
    It's a great saw. Cuts Aussie hardwood like butter....
    aighead likes this.
  5. JBrady
    JBrady Well-Known Member
    Jan 24, 2019
    113
    NE OK
    I've never been around side shift hoes, but it is hard for me to believe something as new as 2008 would not have hydraulics for that function. Leaving that up to an operator to evenly push the hoe over with the dipper and bucket seems like a sure fire way to bend that frame up in short order. Are there mounting points for a cylinder in there and maybe the cylinder was damaged/removed and never put back on. I'd start with the dealer website and look at their parts diagrams and figure out what you have going on.
    P.S. - That saw is awesome!
  6. Welder Dave
    Welder Dave Senior Member
    Oct 12, 2014
    5,252
    I think it was common to have manual side shift on the older hoes but you had to tighten bolts up once in the position you wanted and loosen them to move the carriage to a new position. I think you'd also need a way to lock it in position with hyd. side shift. Maybe look and see if JCB has hyd. side shift and how it works.
  7. Skipo
    Skipo Member
    Feb 23, 2021
    6
    This backhoe side shift locks into place with a hydraulic lock. So you hit a button, it unlocks then you use the boom to slide the side shift across then hit the button again and it's locked in place.
    No there was never a hydraulic shifter mounted on this machine. Maybe it was an extra option you could add on. I have emailed a dealer but haven't had a response. That's why I found this form. Also I wanted to see if anyone has done it before as I don't really want to pay over price new Holland parts to do this.
  8. Welder Dave
    Oct 12, 2014
    5,252
    Do you have an extra hyd. valve?
  9. Skipo
    Skipo Member
    Feb 23, 2021
    6
    I think so. There is an auxiliary line the I think I can hook into
  10. Skipo
    Skipo Member
    Feb 23, 2021
    6
    aighead likes this.
  11. Skipo
    Skipo Member
    Feb 23, 2021
    6
    Just a little log to start on today
    aighead likes this.
