OldandWorn
I finally got the last bit of trench after the culvert finished on my neighbor’s property. That was after 3 weekends of hand shoveling because it was too wet for machinery, a weekend with 8” of snow which I didn’t work, and this past weekend with beautiful weather. Since my neighbor filled most of the trench with gravel for his drain system, and I haven’t finished filling the trench on my property, the trench before and after the culvert are the only major parts that I had to fill all the way to the top and I’m finding out that fill dirt is at a premium. When I was digging the trench I placed the sod along side of the spoil pile just to keep it separate but I didn’t have any intention of reusing it. The wet weather in the past month kept the sod in pretty good shape and most of it had about 4” of soil still attached to it. After scratching the ground for every last bit of dirt from the spoil piles I was still short so I used the sod to get to the top. I’m guessing there will be settling over the next few years and I may have to top off the trench from time to time but every little bit helps and it has a nice finished look. I’m most likely going to need some fill hauled in when I continue with the trenching as I can’t think of anyplace on my property that wouldn’t contain a lot of rocks.
Question…..Has anyone ever used plastic under their spoil piles? I have a large 6’ wide roll of heavy black plastic and I was thinking about trying it. Since I can dig and fill only a small amount per week the sheet wouldn’t have to be but maybe 60’ long and could be reused if not too torn up. I want it close to the edge of the trench so I would have to roll it out as I go to keep the wheels and stabilizer off of it. I’m hoping this would save on cleanup time and allow me to reuse almost all of the dirt if I find that I’m running a little short. Also, the hill is going to be a dirt eater which I will explain later.
The black angled line with debris and soil around it is the last 30’ of trench going into the culvert that I finished this weekend.
I ended up putting a lot more rock on top of the gravel just to get rid of them. There are actually 2 natural paths for the water. One of which is under the big rocks slightly to the right of center which I think is coming from under the culvert pipe and the little stream flowing across the pic which is the water coming out of the pipe itself.
I saved the really nasty clay and rock spoil piles for last in case I needed some more dirt. I did have to use some from a pile which is to the left just out of the pic and the one in the pic got spread out and lost after I was done filling. It actually looks pretty good down there now.
I’m happy with the way the vegetation came back under the spoil piles at the start of the run. There are even a few small weeds growing on top of the trench already.
