tractormech
Hello all-I'm looking at 2 older backhoes for real light use on a home place. The first is a 210B John Deere and the other is a 480L Case. Both are 2 wheel drive. It would be used to pick and carry more than anything. The JD has a regular gear hydraulic pump-not the piston pump. It has a 219 or 239 motor and a Borg- Warner shuttle shift rebuilt 7 or 8 years ago and less than 20 hours on it since then. I rebuilt it for the guy. The case has a 4b 3.9 non turbo and it looks like the same transmission. Both have been sitting up so I know I can expect blown hoses and leaking cylinders on both. If you have any experience or constructive input I'd appreciate it. Thanks
