Adding a case drain line to a Cat 259b3
Howey Matt
Howey in the Hills, FL
My new trencher attachment has a 3rd hose for a case drain, so I need to add a case drain hookup to the machine. I've found some writeups for other makes and models, but not for the Cat 259b3.
Does anyone have any experience with this? Where would be the best and easiest spot on the machine to tap into a drain line?
Thanks in advance.
Howey Matt
Does anyone happen to have a hydraulic schematic for this machine they'd be willing to share? I'd like to tie the attachment case drain into an existing circuit but I don't know which location would be best. Where do they connect the attachment case drain on the machines with high flow?
56wrench
alberta
Just make sure its t’eed into somewhere with zero backpressure or directly into the reservoir above the oil level. Most hydraulic return systems on machines have some amount of backpressure and will cause the seals to leak on some hydraulic motors
Howey Matt
There's a Manual Loader Lowering Valve that connects directly to the drain manifold. It basically allows you to lower the arms manually without the machine running. The current plan is to tie into the low-pressure side of that valve. That seems like the best option to me.
Howey Matt
Just to confirm, I tested the pressure on the hose between the lowering valve and the drain manifold. 0 psi with the machine running, so I should be good to go.
Howey Matt
I was able to put a tee on the low-pressure side of the Manual Loader Lowering Valve - basically between the valve and the drain manifold. From there, I ran a hose to the back of the machine, up to the loader arm, and then to the front of the loader arm with the other quick connects. I've just got the hose zip-tied for now.
I tested the trencher attachment and everything seems to be working well. I'll keep an eye on it. Thanks for everyone's help, especially @Nige for the hydraulic schematic.
