SlatcoAu
Started on the trans replacement on my A25 this weekend. Bit of work for certain. Some takeaways for those who have not done this:
- Fuel lines on my truck were similar to airbrake hose from the tank and then to a adapter fitting to some type of metric flare. I had problems finding plugs so ended up having to drain the upper tank to prevent fuel from free flowing out.
- Make sure your front tie downs are straight otherwise the bumper will not want to come out easily.
All in all not too bad, it will be way harder re-installing.
Next steps are to pull the oil cooler and send it off for cleaning testing and replace both front and rear crank seals.
