55.5° N 770A
Hey every one, thank you for letting me join the fun of heavy equip chat.
I manage/ maintain a northern Canadian drive to hunting & fishing lodge, where our access road is serviced by my self equipped with an older 770A Jd motor grader , im having issues with the blade slide cylinder and what I belive is worn V blocks allowing the cylinder to contact the fittings to the blade chassis and has knocked out the threads? Is there any form on mounting bolt on the cylinder that can be shimmed as the pins have been welded to the blade on the working ( blade end ) and removal at this point means removing the entire blade to access the cylinder and schematic pics or sage wisdom would be appreciated,
Tyvm from the great white north
Jeff
Jeff
