Oh no, I'm getting one. I just can't resist. I have definitely heard some negativity about a skid steer with a dozer blade. I've found an 8' grouser 1300 I'm interested in. I would love to do some fabricating on it. I have an idea for a multi shank ripper that folds down and then flips up as a guard. I'm sure it will work but it might be too expensive of a fabricating job to justify.
The Grouser 1300 is made out of cast iron,so fab anything too it will be a chore in it's self.I have one ,which for what i do is works good(backfill trenches and lots of it).The blade has skids that are adjustable,which helps.The cast blade doesn't scarer very good at all.The early Grouser blades were steel,which worked better when polished.
I also have a Cat blade that is all steel and works better as for actually dozing.
I also have a box blade that has the ripper teeth on it and was 3-point hitch that i had a skid loader plate made for the back of it and left the 3-point in front like it was so if i wanted to use it on a tractor i could,Made a laser plate pole on the 3-point hitch .Can remove it and the skidloader plate off the back.Bolted not welded.
Sorry no pictures camera went on the blink,neew to get new one,just haven't did it yet.
