Robbie Antonson
First post here. Also do not know how to sign up on forums very well either(do not venture from the 3-4 forums I belong to).
Anyhow, Cummins mechanic(In AK(1980'S), worked on it all, Boats, Gens, HE, Tractors, ETC) in the past, now work for my self on Toyota Land Cruisers. Anyhoo.
My BIL wanted help with a 534D-9 that will not go into forward or reverse. the boom will lift up and down, extend. But the Forks will not rotate by the button on the Joy Stick. Do not feel this related to the Fr/RR issue.
Things I have checked. Power was routed out the approbate wires on the switch when The Parking brake switch in it positions(based on Wiring diagram). Yes, no start when engaged, no power to the Forward and reverse
solenoidConnectors. when engaged. When not engaged, Engine will start. Power to Solenoid connectors will happen when the selector switch is approbate location. Ground is good to the Solenoid connectors. I have not been bold enough to try and
engage the FR/RR solenoids with power to see if the TH will move. Plain scares me to be inside next to the wheel.
I did repair many rubbed thru wires on the wringing harness that goes back to the Pump and the Starter Relays. Harness is in good repair at this moment.
The inching Valve was leaking a good amount, so I replaced it with one off another machine that is down, this valve does not
leak.
I have looked in the past threads for any info I could glean, I also did a search in this forum for the JLG 534D-9. Read all the threads I could read. I did call JLG, but only got voice mail, and no return call.
I may of over looked the Filters as a issue. I do need to change them.
I did down load the on line service manual, but this does not have a trouble shooting tree for this issue(or i may of missed it in the 368 pages), or any issue really. I have some of the original wiring and Hydraulic diagrams. Which are help full. And all that stated, I am at a loss at what to check next(after replacing the Hydraulic fluid filters).
My premiss, is that if the Solenoids have power with the gear selector in it appropriate place, then the electrical
circuit is working. So it should move. I do not own gauges and test hoses. If I will need these, I may need to pass on this for
my BIL. I am not interested in spending close to $700 for a one off job.
So any suggestions that I can do to help my BIL with his 534 would be greatly appreciated.
Thanks in Advanced.
leak.
Thanks in Advanced.
