977l right pedal doesn't hold in reverse
Discussion in 'Track Loaders' started by James Phelps, Jun 12, 2018.
Tags:
  1. James Phelps
    James Phelps Member
    Jun 12, 2018
    5
    Laurie, Mo
    Greener than a algae covered frog. My Cat 977l is getting to where it is difficult to keep the right track stopped when backing up. Is this a steering clutch or a brake issue. I checked the linkage and is adjusted as short as possible. Does that mean I need brake work? Thanks.
  2. DMiller
    DMiller Senior Member
    Feb 22, 2010
    3,372
    Retired
    I would start by checking under the covers as to brake lining, clutch linings and any play in bearings. Gonna have to open it up to see, cannot just say it is until get eyes on the components.
  3. James Phelps
    James Phelps Member
    Jun 12, 2018
    5
    Laurie, Mo
    Thank you. I will pull the cover off and look.
  4. James Phelps
    James Phelps Member
    Jun 12, 2018
    5
    Laurie, Mo
    Is this the brake or is it on the inside of the wheel?
  5. DMiller
    Feb 22, 2010
    3,372
    Retired
    Brakes should be Inside the housing, wet brakes wet clutches. That a closeup of the Drive Sprocket?? You need a service manual to get you pointed the right direction, guessing won't get you far.
  6. bam1968
    bam1968 Well-Known Member
    Nov 2, 2014
    218
    Excavating Contractor
    IA
    On the back of the machine below the fuel tank you should see two triangle shaped covers. There should be 3 bolts that hold down each cover. Take the covers off and you should basically see the head of a 3/8 bolt. Tighten that bolt up tight and then back it off 9 'clicks' on each side. (when you back it off you will be able to feel the clicks). That's how I was told to adjust the brakes on the 977L that I had. Hopefully yours is the same.
  7. James Phelps
    James Phelps Member
    Jun 12, 2018
    5
    Laurie, Mo
    Thanks for your help. I have a manual but it was showing how to adjust a 11k serial number and mine is a 14k. I will try to find the band adjuster tomorrow..
  8. James Phelps
    James Phelps Member
    Jun 12, 2018
    5
    Laurie, Mo
    I found the triangle cover. I had to take off a side cover to get to it. It was up under the fuel tank. It adjusted up. Thanks for the guidance.
