973 drive motor
Discussion in 'Track Loaders' started by gwhammy, Jun 19, 2021.
  1. gwhammy
    gwhammy Senior Member
    Nov 21, 2013
    362
    missouri
    One of the drive motors on my 973 has a slow leak from the motor into the final drive compartment. Takes 30 to 40 hours to leak around 5 gallons. Cat doesn't support hard parts for these motors anymore. I found a used one and plan on trying to fix this one for a spare. Are the bearings and seals available? It shows no metal and pulls strong. It's a 86g serial number.
  2. Tones
    Tones Senior Member
    Mar 15, 2009
    2,024
    Ubique
    The bearings should have numbers stamped in the outer race. They represent all the dimensions of that bearing so give them to your local bearing shop and see what they can find. It pretty much for seals, give the the inner and outer diameter's, the thickness. The seal should be a viton lip
    Cat977 likes this.
  3. Nige
    Nige Senior Member
    19,033
    The answer is - "it's complicated".
    There are 37 hits on drive motors for an 86G prefix machine and there are at least a dozen different Part Numbers. Some Part Numbers have "Type 1" & "Type 2" motors for the same P/N. I haven't devled into the differences etween the two types.
    If the motor that you propose to repair is the original from the machine then either the Part Number off the tag on the motor or a full Serial Number is going to be required. TBH I think both together would give the best chance of success.
    Vetech63 and Cat977 like this.
  4. gwhammy
    Nov 21, 2013
    362
    missouri
    Thanks, it seems nothing is simple in my world. I've got a real good parts guy at the local cat dealer. I don't know if it's the original or not, it shows signs of someone being into it before.
  5. Nige
    Nige Senior Member
    19,033
    In that case I would suggest that the best way would be get the P/N from the tag on the motor.
    Failing that it would be a case of pull the motor apart and see if anything significant internally has a Part Number marked on it and try to work backwards to the motor Part Number that way.
    A quick look reveals a slew of Service Magazine articles and Special Instructions regarding the motor. Not surprising I suppose if the Part Number changed so many times.
    It's worth mentioning that there was a Steel Mill (slag) arrangement for the 973 therefore some of the motors may be specific to that Arrgt. This would narrow the field down somewhat.
    Cat977 likes this.
  6. gwhammy
    Nov 21, 2013
    362
    missouri
    Thanks, I appreciate the info. One thing about it the motor is useless the way it is so it's no loss tearing it apart.
    Cat977 likes this.
  7. Cmark
    Cmark Senior Member
    Jan 2, 2009
    2,779
    Those motors are a nice heavy built unit with big old taper roller main bearings. The seal in in a removable carrier which bolts to the case and replacing it is a matter of minutes once the motor is out. If the machine works OK then the bearings should be good.
    By the way, are you sure it's the motor? A leaking parking brake will fill the final drive with transmission oil as well.
    Nige, DB2 and Cat977 like this.
  8. gwhammy
    Nov 21, 2013
    362
    missouri
    I thought about that also but don't know enough about the system. I'm guessing there's no way of knowing which one is leaking without tearing it down farther.
  9. Nige
    Nige Senior Member
    19,033
    Pressurize the park brake circuit with a portapower.?
    Cat977 likes this.
  10. gwhammy
    Nov 21, 2013
    362
    missouri
    Here's what we come up with today. The o ring on the drive shaft going into the motor is not cut. Looks like we are going to reinstall the motor and put a pressure gauge on the case drain line to see how much bypass it has.
    The brakes use around 200 psi to disengage them. Going to take the line off and block it and see if the brakes hold or not. We think maybe they have been leaking and not completely taking the brakes off which is the reason for the glitter look in the oil.
    A logger friend of mine said he had a tree processor blow a seal on a hydro-stat. It dumped all the oil immediately.
    I'm pretty sure it's narrowed down to the brakes now but time will tell.
  11. Cmark
    Cmark Senior Member
    Jan 2, 2009
    2,779
    As Nige said, test the brake system with pressure. It's pretty easy to rig up with a gauge, valve and shop air. Pressurise the system, close the valve and see if it leaks down.
    The way to test for excess internal motor leakage is to check the case pressure. There should be a test point there already. You should have no more than about 2 psi. Check at high idle stationary and also high idle full travel speed.
    Nige, Cat977 and DB2 like this.
  12. Cat977
    Cat977 Senior Member
    Feb 19, 2006
    355
    Machinist/Millwright
    Madison WI
    Good simple tests! Gotta love'em! Cmark's test I think doesn't actually call for the brakes to release, it just looks for leaking. As for o-rings they can look pretty good but still wear/distortion/hardening can still have them leak. New o-ring has got to be cheap insurance. Glitter in the oil anywhere should be tracked down.
    gwhammy and Nige like this.
  13. gwhammy
    Nov 21, 2013
    362
    missouri
    These old mechanical machines are a lot easier for the old timers I hang with. Time will tell but I'm feeling better about it with more info. Thanks
    Cat977 likes this.
  14. gwhammy
    Nov 21, 2013
    362
    missouri
    I got sent the wrong direction by a couple mechanics. The brakes are toast, evidently it's been leaking from the apply pistons and not disengaging the brakes completely. Motor is fine. Hopefully it didn't tear up any hard parts when we finally get it off this coming week. If I had done a little more digging it would have been easy to diagnose but I trusted the advice I had gotten when we first found extra oil in the finals.
    Cmark likes this.
