Thank you for visiting HeavyEquipmentForums.com! Our objective is to provide industry professionals a place to gather to exchange questions, answers and ideas. We welcome you to register using the "Register" icon at the top of the page.
We'd appreciate any help you can offer in spreading the word of our new site. The more members that join, the bigger resource for all to enjoy.
Thank you!
Sn 2ds 2296 need help with code. 030. 248.02. 030. 271.05. 079. 190.08 079. 467.03. Intermitten no steer . This is the active code in dash need help with this problem please
Are all four of the Codes you posted above Active.?
First two are in the Monitor System
248.02 is a lack of communication between the ECM's over the Datalink. Can be caused by a blown fuse.
271.05 is the Action Alarm (beeper) in the dash panel. Does it sound on the self-test when you trun the key on.?
Second two are in the Transmission ECM.
190.08 is the ECM reading an abnormal signal from the engine speed sensor.
467.03 is the RH steering pedal position sensor. This sounds promising. Troubleshooting procedure below. I would not suggest that you replace the sensor immediately. There could be a harness or connector problem.
If an electrical schematic would help please say so.
