leadfarmer
I decided to make this a new thread for the purpose of future people searching this topic, so more people see it, and because my other thread is on various topics.
Caterpillar 955L SN: 85J10466
Alright, back to the oil level issue that I thought was myself incorrectly adding fluid to the bevel gear case instead of the transmission.
After some more hours of seat time, I can confirm with certainty that the transmission fluid is transferring to the bevel gear case. It is doing so at a fairly high rate. Several gallons over a few hours.
I have been removing oil from the bevel gear case through the filler tube and adding fresh fluid to the transmission so I can accomplish the work I need to get done. I need to finish a few more projects and then I will have some downtime for a repair.
I did some more research and found several other places saying the steering clutch pump can suck oil out of the transmission if the pump seals are bad or the steering clutch oil screen is clogged. Here is one: https://www.yesterdaystractors.com/cgi-bin/viewit.cgi?bd=crawlers&th=53142
Is it worth checking the steering clutch pressure to try and confirm this? It sounds like the steering clutch pump is getting fluid one way or another if the seals are bad. I also read in the service manual that the fluid pressure won't be at maximum condition unless the clutches are new. Given that the steering clutches function without issue, I'm guessing there isn't much value in checking the pressure.
I will pull the steering gear oil screen again and clean/inspect it first.
How difficult is it to service the steering clutch pump? Any tips and tricks for removal, overhaul, and re-installation? I didn't find anything in the 85J 955L service manual I have about servicing this pump.
If it ends up that the actual problem is the pinion seal leaking directly between the transmission and bevel gear case (multiple sources say this is unlikely to fail) then I will just have to live with it and keep playing the oil shuffle game as I am not up to pulling the transmission at this time or in the near future. A few gallons of oil will just be the cost of getting work done. Given the high rate of fluid transfer, that makes me suspect the issue is with the pump rather than the pinion seal.
