Oh wow, sorry guys i hadnt checked back here in a while, got busy on other stuff. Thanks for all the thoughts and information everyone. I have measured the inner and outer springs. Inners look good but a number of the outers are on the low side measuring around 106mm. The part where the clutches hook up to the final drive felt ok Cmark. Nige im thinking they must have made an error and mixed up the number of disc and plates, my parts catalog calls for 28 friction plates and 30 metal discs. That should be 30 friction plates and 28 metal discs imo. From an engineering standpoint i cant see any way they would design a metal disc to be on the end in contact with the metal of the hub, metal on metal slip contact = not correct imo unless there is something im not understanding here. Should be metal>friction>metal>friction.... all the way through imo, not metal>metal,>friction>metal... Must be a mistake. Im going to stick with 15 friction 14 metal per side unless someone can convince me otherwise. I guess I should get some new outer springs though.
