955K shifting
Discussion in 'Track Loaders' started by tomb76131, Sep 14, 2018.
  1. tomb76131
    tomb76131 Member
    Jun 18, 2016
    14
    Fort Worth
    Just changed all the fluids, filter, cleaned the screen and magnet now she shifts into all three forward and reverse gears, you can feel the shifts, but it doesn't change speeds only looses power by being in higher gears. She was fine until I changed everything. Ideas??
  2. Theweldor
    Theweldor Senior Member
    Feb 17, 2018
    264
    Western, NY
    Fuel Filters?
  3. tomb76131
    tomb76131 Member
    Jun 18, 2016
    14
    Fort Worth
    complete fluid change and all filters including fuel
  4. tomb76131
    tomb76131 Member
    Jun 18, 2016
    14
    Fort Worth
    Trans temp and pressure are running in the green on the gauges
  5. Nige
    Nige Senior Member
    10,092
    What type and weight of oil did you put in the transmission..?
  6. tomb76131
    tomb76131 Member
    Jun 18, 2016
    14
    Fort Worth
    30 weight caterpillar
  7. Old Magnet
    Old Magnet Senior Member
    May 11, 2010
    1,336
    Corralitos, California
    Was that 30 wt TDTO TO-4 spec?
  8. tomb76131
    tomb76131 Member
    Jun 18, 2016
    14
    Fort Worth
    Went by the book
  9. sawmilleng
    sawmilleng Well-Known Member
    Jul 9, 2009
    90
    Central Kootenays, Canada
    Hi, Tomb,
    I came across a similar situation with my D4D some time back. When I got it, the powershift seemed weak, like it had a sloppy torque converter. It wouldn't even spin the tracks in low when going up against a tree. Trans pressures were fine.
    Finally had to pull the thing apart 'cause a engine liner got a pinhole through into the water side.
    Pulled the whole transmission/torque apart into little bitty pieces.
    The only thing I could find wrong was the torque/trans pump intake screen was plugged nearly solid. The previous guy was a gyppo logger and had brazed up a crack in the torque housing without taking it out of the machine. I presume he drained the oil but the brazing had carbonized a bunch of oil in the torque. It cracked off the inside and plugged the pump intake screen.
    I can't say for sure this was the problem in my machine because I haven't got it back running yet but I went through the torque with a fine tooth comb--even bribed a Cat guy (with lunch) to give me the wear limits on the torque to prove to myself it wasn't worn out! The rest of the transmission was fine.
    I'm presuming the transmission was sluggish because the torque wasn't getting enough oil into it to make it work properly.
    Hope this helps....
    Jon.
  10. Old Magnet
    May 11, 2010
    1,336
    Time to run some pressure checks!
  11. Nige
    Nige Senior Member
    10,092
    I think so........... a Serial Number would assist in locating the correct specs for the power train.
  12. tomb76131
    tomb76131 Member
    Jun 18, 2016
    14
    Fort Worth
    71j2206
