Nice to hear from you fest777. About me, just a lucky guy that had a few good breaks. Went to technical college 3 years full time 4 years half time. Built papermill equipment for Beloit corporation, on they're drive floor, was an inspector for Warner Electric Brake and Clutch, built test stands for Nelson Muffler and Filter Research. Was lucky enough to land the Instrument Makers job. All I can say is I’m grateful. The journey I had in life was, what I learned along the way was a ticket into something new to learn about. There’s men on this forum that ran the loaders, Dozers, ect., or fixed them for a living. They have the experience to know what is going on when you have a breakdown, or need help trying to rebuild something. I just worked on a lot of different machines. What was it that caused you to revive the 955L? I'd love to hear that story. Well, I dug out the Instrument Maker position description fest777. Sure doesn't mean I’m any better than my fellow man!
Position Summary
Under general supervision perform as a highly skilled machinist in the design and creation of unique, highly intricate, and precise scientific equipment. Fabricate and modify specialized laboratory equipment utilizing knowledge of materials, methods, and machine tools to fabricate the required item. Maintain and repair equipment and mechanical systems for Physical Plant, University Departments including diagnosing, and repairing or manufacturing new parts.
Fabrication and modification of specialized laboratory equipment.
Expertly use all shop machines and tooling to fabricate parts.
Assist researchers and students in designing specialized lab equipment. Modify existing lab equipment to perform functions other than the original design. Work assignments may begin with drawings, sketches or very often only verbal instruction given by a professor, student, or engineer.
Fabricate parts for obsolete master timing systems for campus clocks, bells, and Radio Hall.
Repair and modify photography equipment such as lens adapters, extensions and remote controls not available from manufacturers. Modify film developing equipment to suit the user functions and demands.
Select proper materials best suited for the functions of the equipment. Materials may include stainless steel, plastics, glass, aluminum, brass, spring wire and steel, tool steel, etc.
Fabricate jigs and fixtures to hold special parts for forming or machining.
Maintenance and repair of equipment and mechanical systems for Physical Plant and other University departments.
Diagnose the reasons for mechanical failures and recommend suitable repair or modifications.
Manufacture new parts to replace broken or worn parts in emergency cases and when not available. Replace new parts when available.
Repair compressors, gear reducers, conveyors.
Repair pumps of all kinds such as vacuum, sump, split case, vertical, fire, water, and sewer ejectors. This requires the making and fitting at very close tolerances of shafts, bearings, seals rotary seals, impellers, gaskets, etc.
Repair of elevator in general including cable replacements, bearings and shafts, safety equipment and hydraulic pumps. Drop test in accordance with safety and state codes.
Repair, replace or upgrade electric motors adapting ball bearings in place of sleeve bearings. Sleeve bearings are also made and fitted when needed.
Repair steam turbines, electric generators, boilers, coal handling equipment, water treatment systems, pumps and other related equipment at both heating stations or campus buildings.
Repair of overhead doors, silo unloaders and barn cleaners. B8.1. Fabricate and install shafts and bearings. B8.2. Replace springs, cables and broken panels.
Repair and fabrication of parts for a variety of equipment used by Physical Plant. B9.1 Carpenter Shop - Table saws, thickness planers, routers, jointers, and band saws. Sharpen handsaws, table and radial arm saw blades, planer blades, router blades, molding cutters, and drills. B9.2 Sheetmetal Shop - Repair and change blades on hydraulic metal shears. Repair metal brakes, lock formers, nibblers and pneumatic or electric grinders and hand tools. B9.3. Paint Shop - Repair paint sprayers, line strippers, sewing machines, and engraving equipment. B9.4. Machine Shop - Repair and maintenance of lathes, mills, drill presses, band saws, grinders, and other miscellaneous equipment. Grind drills and set up special tools, milling cutters, and drills for shop use. B9.5. Plumbers, steamfitters and electricians - Repair pipe threaders and dies, hydraulic jacks and tubing benders, core drills, etc. B9.6. Grounds - Disassemble, repair and maintain power brooms, lawn mowers, snow plows, thatchers, aerators, air hammers, hedge trimmers, weed eaters, etc. Sharpen and repair gang mowers. B9.7 Service Garage - Make and repair parts for large vehicles.
Repair fans, gear reducers, air conditioning, and other related equipment.
Advanced knowledge of characteristics and properties of materials worked with such as hardness, strength and durability of metals, alloys, etc.
Knowledge of machine and mechanism design, and ability to apply such knowledge and personal ingenuity to solve difficult problems in making repairs and new parts.
