Junk runner
I have a 1986 953 I hadn’t used in awhile because it wouldn’t move. I finally got around to working on it and checked the pressures. I determined it needed a filter so I changed the filter and oil. When I started it it wouldn’t move but the transmission whined when trying to go forward or backwards. I checked the pressure at the brake check port and it was 0 sitting or engaging forward or backwards. I put charge pressure straight to the brakes and the machine goes forward and backwards but very slow. I would appreciate any information on what to do next. The cab is up and the brake lever is pinned with a 5/16th bolt. The machine worked fine before the filter issue and there wasn’t any metal in the filter.
