Queenslander
Our 950H, JAD02141, won’t engage in any speed or direction.
The problem has occurred a couple of times over the last few months, but after a few seconds moving the direction switch or lever back and forward it has always reengaged.
Worked fine this morning but nothing after lunch.
Park brake is releasing, fuses ok, voltage ok and no active codes showing.
Speed and direction display on the dash doesn’t change when moving the lever through all speeds and either direction... showing 4N
Reverse beeper sounds on the thumb operated direction switch but not with the hand lever.
I suspect the hand lever but assume we will have to connect et to verify.
