spock
Hello All,
I'm looking for some help with my Lull 644. Last spring it started intermittently not responding when I put it in gear, but it seemed that the more the machine was used, the less this occurred. At the job the machine is at now, everything was working normally most of the time, but occasionally the machine would pop out of gear with the stick not being moved. Usually slipping the stick back and forth from neutral to forward or reverse would solve the problem until the next time. This morning, it would not go into gear no matter what I tried. Last year when it was not moving for a few days, I tried a different gear shift lever assembly, and it didn't help. If anybody knows what I should try next, I'd appreciate hearing from you. Thanks.
Best Regards,
Spock
Best Regards,
Spock
