Hi,
SN: 6BK00136
1994 Caterpillar 623F
I have a 94' 623F Scraper that has a reverse problem. I can't see anything behind me! Jk, jk. My real issue is that my machine has reverse when the machine and all its fluids are cold but after warmed up, it won't go into reverse. I do feel it engage because when I take it out of reverse and shift back into neutral, you can feel a little nudge, if that makes any sense? After the machine is warmed up and you go to throw into reverse, you can hammer down on the pedal and it revs the motor as if it's in neutral. Although, if I mess with it long enough while everything is warm, going from neutral to reverse, it will sometimes all of a sudden find reverse and work normal. As soon as I take it out of reverse, back into neutral, and back again into reverse, reverse is gone again. Is this situation familiar with anyone? I've got a quote from CAT for $36,000.00 USD worst case scenario of a reman transmission swap, labor included.
Thanks,
Chad
SN: 6BK00136
Thanks,
Chad
