Are you following this?
The purpose of the Service Test button on the keypad is to provide the operator a method to manually test the Service Brake, the Parking Brake, and Secondary Steering (if equipped). The left light is the Service Brake. The middle light is the Parking Brake. The right light is Secondary Steering.
Press the Service Test button to cycle between the three Service Tests. If Secondary Steering is not installed, the test will only cycle between the first two Service Tests. Press and hold the button to activate the Service Tests assuming all other criteria are met. While the Service Test is active, the light for that test will blink.
The following criteria must be met to activate each Service Test:
Service Brake
- The light for the Service Brake Test must be on.
- The machine must not be moving.
- Depress the left pedal at least 95 percent.
- The parking brake must be disengaged.
- Engine speed must be greater than 1700 rpm.
- Press and hold the button for 2 seconds.
- Shift the transmission selector to Forward or Reverse.
- The machine must not move.
- If the machine moves, repair or adjust the service brake before putting the machine into service.
- Return to Neutral to complete the test.
Parking Brake:
- The light for the Parking Brake Test must be on.
- The service brake depressed less than 10 percent
- The parking brake must be engaged.
- If the machine moves, repair or adjust the parking brake before putting the machine into service.
Secondary Steering: (If Equipped)
- The secondary steering option must be installed.
- The key must be on and the engine must be off.
- The secondary steering indicator will display on the LCD of the instrument cluster for 10 seconds.
- While the test is running, provide the following steering inputs:
- Steer left
- Steer center
- Steer right
- Verify that the movement of the machine aligns with the steering input
- If the secondary steering does not turn on, repair the system before putting the machine into service.
