'93 Deere 310D front differential locked and cant unlock
Discussion in 'Tractor/Loader/Backhoes' started by hellspcangel911, Jan 16, 2018.
  1. Desertwheeler
    Desertwheeler Senior Member
    Jan 25, 2014
    382
    Miner
    Ca
    Does the 310E have a shuttle valve for the MFWD? I have been working on a 210le and it has a shuttle valve for it and I had to replace the one for the park break because it somehow got bent or the spring became weak. IF its the same it is very easy to pull out and inspect.
  2. hellspcangel911
    hellspcangel911 Member
    May 18, 2015
    21
    CT
    All the 310 and 410 models of this generation use a solenoid as pictured in the schematic, item #9, PN: AT149770, and utilize a switch # 2, PN: AT86950 to confirm engagement/disengagement, illuminating the indicator. Once the weather clears up I'll check if I'm getting power at the soleniod, if so is the solenoid actuating appropriately or does it need to be cleaned/ adjusted.
  3. Desertwheeler
    Jan 25, 2014
    382
    Miner
    Ca
    After looking that part up it is completely different than the 210le.
  4. hellspcangel911
    May 18, 2015
    21
    CT
    went to check it but everything was working properly. Ill keep a meter in the machine should it act up again I can troubleshoot. thank you all for your help
