I have a Bobcat 863 non Boss sn 514428790. Valve light on Bics is flashing 3 times, I have 14.5 volts to coil new coil and valve. The control valve doesn't have lock out solenoids. Aux hyd lights on panel above switch come on, I hit thumb switch doesn't seem to move fluid. Took nuts off on top of aux coils hit thumb switch seems to be magnetized. Don't have attachment on I just figured lines would load engine. Lift tilt work brake release and holds. I've poured over all posts here to get where I've got so far. Just trying to get everything working if possible. Any and all suggestions would be appreciated.
