clearprop
I talked to the local JD service manager. He tells me the ECM calculates DPF level via 3 different ways and this code means of the 3 different calculations, 1 of them does not agree with the others.
This causes the machine to run a regen about every 4-5 hrs of operation.
I would assume one way is the DPF differential pressure sensor, don't know about the other 2. When I asked him about testing it he keeps wanting to just come plug the computer in $$$$.......I would like to troubleshoot wiring and voltages on my own prior to some service tech wanting to come play with his laptop.
I have a shop service manual but it has nothing in it about this code or about how to test the sensor.
By studying the wiring harness I can see it uses a supply voltage of 5V, a return (GND) and a signal. Any idea what voltage the signal should read engine off and engine running with clean DPF, and with dirty DPF?
If I at least test the sensors out I might stand a chance...?
