821B stuck in first
Brian DeMark
New York
I have a CASE 821B and it is stuck in first gear, reverse works fine. I had a few times when using it where all the sudden all gears would work fine without any issue and then randomly it will act up again. now it won't come out of first at all. I had case dealer send a tech and he didn't really test much and said he thinks it's the gear selector to the knock down button but couldn't really tell us. any help is appreciated
Coy Lancaster
Arkansas
service tech
It's possible that the gear selector is bad but there needs to be more test done before condemning anything. If you have a service manual there are procedures to test he gear selector and the solenoids in the trans control valve. There is also a trans control module behind seat in blower area that needs to be checked also.
Bigbert
Germany
Consulting Engineer
Fully agree with Coy.
Not sure what would happen if kickdown button got stuck. Button which is fitted on front end of gear switch.
ZF 4WG180 transmission?
If you need a manual let me know.
Brian DeMark
New York
ok, I went to the dealer today to get some more into. service said they couldn't test the issue because it didn't happen when he was there. so, I explained how it only happens when its warm, so he told me its probably a relay and told me to get it doing it and swap some relays around to see if it fixes the issue.
Brian DeMark
New York
yes I do need a manual that would be awesome, I can pay. thanks you so much
Brian DeMark
New York
Hi Brian,
there are no relays between gear selector, TCU and solenoids.
See the manual in PM and come back if you need more details.
Hey, thank you got the manual. I appreciate that. Not being to mechanic friendly I was able to read and understand somethings about that. However, Unless I missed it I didn’t see any problem solving issues. Also I see you said there is no relay that would cause this issue. In your recommendation where should I start?
Bigbert
Germany
Consulting Engineer
Hi Brian,
I'd strip the steering column plastics (if there are any) to get access to the plug from gear selector (DW2?) to wiring harness. Might be a mate-n-lock type.
Just be sure: It is a ZF 4WG180 with DW2 selector and TCU EST17 or 25?
So, as soon as you get the issue, check whether signals on plug change or not when moving selector.
See the diagram of a DW2, clearer than in English manual (see it as a German language training;))
colours of wires
sw= schwarz=black
gn=grün=green
bl=blau= blue
vi=violet
rt=rot= red
ge=gelb=yellow
rs=rosa=pink
gr=grau=grey
good luck
  • 5872_174_001_4WG200._DW2.pdf
